Vehicle “Shivers”/Shudders” and RPMs pulse
FussyFrog
Baton Rouge
Howdy.
Just got our Expo back from 2 weeks at dealership to diagnose and repair weird issue. They were unable to reproduce the issue and therefore did not repair it.
Here’s what’s happening.
At all speeds our car will randomly “Shiver” and the RPMs will bump up about 500 or so.
-notice it more going uphill.
-doesn’t do it when I let off the gas.
-seems to do it more between 70-80mph, have observed at all speeds.
-check engine light is on.
Anyone encountered a similar issue? Ever find out what was wrong?
dcsang
Did they return your vehicle with an active CEL and no diagnosis? Identifying those DTCs should be the first step in properly diagnosing your issue.
F
FussyFrog
Baton Rouge
Yes they did. Twice.
First time we brought it in was for the shuddering and a recall. After two weeks they didn’t diagnose the shuddering nor did they repair the recall.
They then called to ask us to bring it back in for the recall to be repaired and a same day diagnosis for the shuddering. Made no sense how they expected to diagnosis the issue in one day after they couldn’t do it with two weeks. So I brought it back.
Check engine light still on.
Year and engine?
What code(s) were stored with the CEL?
What safety recall?
Orlando, Florida
I agree with Dustin and Gary, torque converter shutter.
We have a 2016 and at steady state highway speeds, if we accelerated just slightly, it would feel like you were driving over rumble strips. Let off the gas and it would go away.
A few weeks ago, I added Shudder Fixx to the transmission. Took it on a test drive and as soon as I got to highway speeds, I could no longer replicate. It fixed it that quick. We have had absolutely zero shuttering since.
For such an inexpensive fix, it is worth a shot. Let us know if it works.
Motorcity muscle
Motorcity
Recommend you have a code scanner put on truck. Will pinpoint the problem area, a misfire can also cause your symptoms . Transmission guy I use for fluid changes strongly recommended against shutter fix or similar additives.
Orlando, Florida
What was his reasoning? I thought Shudder Fixx was simply a lubricant to reduce friction.
Dsurkamp
St. Louis, MO
I put new spark plugs, also checked the gap, on our 2018 Expedtion Eco Boost when going to Florida this year and around 70 when you punched the gas it would shake but if I eased the gas it was fine. Well bought new spark plugs again once I got back from the trip and just put them on. It stopped my issue.
