Tires/ stock rims fitment
longhorn
texas
Hey yall, I am currently getting the readylift 3/2 and was supposed to get the 305 55 r20 tires on the stock rims. Will I have a problem running those tires on the stock rims ? Or even running 33 x 12.5s
Just wanted to check in and see if anyone else has ran those tires on the stock 20 X 8.5 ford wheels.
Thanks in advance
loulblades
Western PA
When I bought my 2018 Expe Max Limited, that came with 20" tires, I knew I was going to put the 2/3" lift kit on. I also knew I was going to purchase 18" (stock) rims so I could get more rubber between the rim and the road when running in the back woods.
For the 18" rims I put Kelly Edge MT 265/70 and for the 20" I used the Cooper Discoverer HT3 275/65 for a little more height, again for more sidewall because I do spend some time on the back roads while pulling a 16' trailer with my tractor on it in the summer. With the 20" tires on, the speedometer shows about 4 mph lower speed than my dashcam, which uses GPS.
I will say with that size 20" tire there is what appears to be less than 1" of clearance at the front of the rear inner fender well so I am glad I didn't go any wider.
I don't know if any of that info will help you any but there it is.
loulblades
L
longhorn
texas
There she is. 305 55 r20 on the stock rims. No rubbing currently, with the 3/2 level.
I think the next move is some 20 by 10s. But a little worried about rubbing. Thanks for the input yall
aksarben
Rockies
Looks nice. What's the 3/2 level? 3" front lift and 2" rear lift?
I have the same rims but in black. Stock height, Michelin Defenders 275 55 R20. Didn't want to throw the speedo off too much.
