Matthew Goulart
First off, thank y’all in advance.
I replaced the blower resistor under the glovebox because wiggling the wires under the dash no longer turned the blower on. But it didn’t fix the problem.
Upon examining the wires and connector, I got it to come on and off intermittently but also got some sparks. The wires into the 4 pin male connector are fine, as is the fuse. But I believe the issue is with the connector that plugs into the resistor.
The local auto parts stores have 4 wire pigtail connectors, but they’re too small.
Does anyone know where I can find the correct connector in a pigtail form, so I can just cut the wires get this fixed?
Thanks again!
Thanks again!
