tire size?
fungog
Mosckow
Good morning to all)
I am writing to you from faraway Russia
There are a couple of questions that I hope to get answers
Available Ford Expedition Eddie Bauer 1998
I would like to order and install a body lift kit 2 or 3 inches
matter what the wheel can be set to one and the other set, and in particular the 24 discs stand up?
and what problems may arise during the installation kit? (Steering) transmission
behavior of the cars on the road much change in setpoint kit?
I apologize for my english, it's Google translator):D
JUST4FUN
Admin
Moderator Administrator
Il
the lift guys will chime in shortly
panda24619
San Diego
its fine. i got most of that. so you want to lift and want to know what the biggest tires you can fit and if your steering and other component will be effected? got it. first off. is your expedition 4wd or just 2wd? and that will depend on what we recommend you do.
F
fungog
Mosckow
Ford Expedition Eddie Bauer 5.4 4x4 with rear air suspension
(torsion bars, front shock absorbers with pneumatic pumping) in general stock
F
fungog
Mosckow
I meant that the center of gravity gets higher, the stability of the machine change?
nvycrmn
Springville, IA
yes, as you go higher, the truck will feel a little more "rolly" but with wider tires, it helps balance it out. i dont know about walnuts but i have 4" suspension lift with 35" tires on 18x9 rims and i never feel like that tank is going to roll.
F
fungog
Mosckow
cool
basically I thought so
and yet what size wheels you can let yourself with the body lift 3 or 2 inches?
