1997 Ford expedition 89000 Jerk in rear when i come to a stop sign or light all suspension had been check front and rear brakes just replaced and hose
craigb36
new jersey
Jerk in rear when i come to a stop sign or light 1997 ford expedition just replaced front and rear brakes and hoses thinking it could be caliper but it’s not does not do it every time i stop i’m thinking the transmission truck has 89000 miles on it
C
craigb36
new jersey
Yes rotors replaced and now when i coast in a parking spot it starts jerking
feels like transmission
Yupster Dog
Moderator
4WD? check transfer case motor
You can check if it is a caliper sticking by checking if one wheel is hotter than the others after a drive.
Ugh_J
Texas, USA
I had a similar problem on my 2015 F-150 FX4, but in my case it only happened when I *almost* came to a stop at a stop sign and then accelerated. Turned out to be the drive shaft front spline shaft binding due to no grease.
Petesexpy
Delaware
Check transfer case and the drive shaft. The U-joints might be worn out.
