Expie died
Randy-IA
plane droppings area
2004 Expedition XLT 4x4 with advancetrac.
Well folks it's been awhile since I've checked in, mostly because the Expy died an unexpected death. It's legs just quit working one day with zero indications that there was a problem. No ambition to move forwards anymore. Goes backwards like it's a child.
It was a sad day. That thing was comfortable!
Transfluid was dark red but didn't smell bad or burnt. It has some age on it 250K plus. It runs pretty good but has a slight vacuum leak I never got around to finding.
I don't have "permission" to post "wanted" ads but if you are near W/loo Iowa I want a used transmission.
For those Chevy haters out there I ran out and bought a 2002 Avalanche 2500 with a big block to replace the Expy. It's still out behind the barn though. I have way too much money invested in it just this past year to give up on it just yet.
R
Randy-IA
Still wondering what may have happened to my transmission. I live far away from a town with no car trailer so getting to a shop is not likely in the near future.
I saw on a different post that nearly the same thing happened to MWzd's expi (https://www.expeditionforum.com/threads/fluid-leak-now-no-forward.55010/). But no resolution was given - if there was one.
I have a lot of irons in the fire and I'm not the fastest 67 year old on the block (I'm the only one within a mile of me so there's that though). But I would like to fix it especially if it may only be a sensor that crapped out.
I'd have to get the testing tools if they're necessary first however. But as I said, it's not the first priority right now. It'll probably still waiting on me once the real spring weather gets here.
Thanks!
R
Randy-IA
Nobody has had any suggestions on the reason my tranny quit going forwards yet goes backwards like nothing is wrong? It's still waiting on me to fix it. I want it back, the avalanche is so uncomfortable to drive!
whtbronco
Winchester, VA
I think there's just not enough info to diagnose it. It could be the column shifter, I mean reverse is first. Maybe it could be shift solenoid or a pressure issue, but that is merely a guess. You might want to get FORScan since it's fairly low cost and you can get a lot of insight into the problem with that.
R
Randy-IA
Thanks! I know I don't have much info to give on it, just what I said above. It's sat for so long now and my old age let me forget to disconnect the battery that now it's dead. Those danged always on items like the passive security light, the radio storage, etc. are annoying in this regard.
It just seemed odd that all was going great and suddenly it just lurched some and started slipping about a mile from home, then quit completely as I turned into the drive.
Can't the shifter be ruled out due to the fact it was already in gear and moving for the prior half hour plus on the highway and county roads? I never crawled under to look but it might be on my to-do list just to verify. If I find it's something like that you have no idea how foolish I will feel...
Regardless, until I finalize it's demise I still have to do preventive maintenance on the current daily driver (the ava). I'm going to change u-joints on it before they die, they are the original plastic retained 'lifetime lubed' factory joints with 90K on them. I think that the 8.1l might put some strain on them.
It might be next week that I'll get the battery charged in the expie and run it in reverse to a place I can crawl under it. Right now it's on a side slope near some wild black raspberry and it's gotten pretty overgrown around it. I'm old with bad knees so I don't get as much done as I used to in a short amount of time.
whtbronco
Winchester, VA
Yeah you can probably rule out the column shifter sine it occurred while driving. No need to feel foolish if by chance it is. I've certainly made my fair share of silly mistakes while troubleshooting recently. We go where our mind takes us or where the pinpoint tests take us.
It could though be as simple as the shift cable linkage having come loose. Seems unlikely to me.
I really think you need a way to read the data stream to troubleshoot this issue, like FORScan. You'll be able to see the what the vehicle modules see that way.
I certainly understand the difficulty getting under and working on vehicles in general. You have me by a few calendar years, but with severe RA I am limited to a few hours at a time.
Good luck with the u-joint swap on the Avalanche. Took me 2 days to get rear joints completely done, used to be that was just a couple hour job.
R
Randy-IA
I guess there is a possibility about the shift linkage but it doesn't strike me as probable since it shifts just fine into reverse and then neutral.
I've looked a little for that FORscan and what I've found is confounding. I don't have a laptop or tablet for starters, only a tower PC and cell phone. And since it really only works for ford it might not be totally worth buying the adapter link (which BTW doesn't work with the 02 avalanche for advanced use which is the only reason I'd want it). I want to modify the TMS (torque management) so that truck can develop some sense of accomplishment. The way it feels right now is like it has a 4cylinder in it. For having only 90K on a 496ci engine that's seriously sad.
This week we are having the heat and humidity like most places are so outdoor activity (for my fat old self) is limited. Especially the type of 'lay down easy - labor to get back up' activity required for driveshaft R&R. LOL!
Cool front coming down is supposed to cool things off the in the next three days or so. I have a few projects to complete before I get back to the expie (new tie rods installed on the Oliver 1755 tractor and set alignment, R&R a chronically flat front tire on the workhorse JD318 garden tractor with the box blade on it, determine why a fuse blew in the JD425 that has the mowing detail, in addition to the driveshaft on the ava).
Around this small acreage it's always something that needs fixing.
whtbronco
Winchester, VA
I agree the shifter is unlikely, but it may be the only option without an OBDII scanner.
Yeah FORScan is Ford only, but still a heck of a bargain compared to other similar products. I have 5 computers for diagnostics. 2 are dedicated Ford, 1 dedicated GM(sold), 2 generic code readers and a generic tablet($1k). Each has their advantages, I use the $1k tablet more than anything, but you gotta have something to work on complex issues with these computer controlled vehicles. Gone are the days of using touch, sound and smell to figure everything out.
You can get FORScan Lite for cell phones and then you'd need a wireless adapter which appears to be $60 or $140. I've never used FORScan Lite, but hopefully someone will chime in to confirm the $60 OBDII adapter will work to read the trans module.
The other option I suppose is to find a mobile mechanic that can stop by with a scanner.
You certainly have enough projects to attend to though. Maybe just drive one of the tractors, :) .
You mentioned the Avalanche isn't very comfortable. I always thought the GM slogan referred to their seats "Like a Rock". haha
whtbronco
Winchester, VA
Well this probably won't make you feel any better, but it's a good read.
R
Randy-IA
Not JUST like a rock, a very ill fitting, too narrow at the shoulder blades, and bumpy bottom cushion rock.
I mention it often, I absolutely HATE leather seats! My wife has heated and cooled leather seats in her Expie King Ranch EL, marginally better but still terrible.
I think the issue is the foam is dead on the seat bottom and I know the power lumbar is broken (I'm thinking the spring has broken because the tensioning motor still sounds like it's working).
R
Randy-IA
It was interesting. Not depressing. I believe that mine might have the broken forward drum.
It's been a year since it broke so I need to get back to it. Cool front just went through with noise and badly needed moisture finally. I have to pick an implement I won at an auction before I go to work tomorrow and I have to work a 12+ hour shift on Saturday. I should be able to look at recharging the battery (if it's not ruined) on Sunday while i work on the tractor steering or the avalanche (one of them can sit there and charge it up some). It's got a full tank of year old gas since I filled it up about 25 miles before it died.
I didn't own an automatic trans until I was about 40 years old because I believed them to be unreliable...
I also have a good running albeit seriously rusty Ram 2500 that the OD is bad in. I bought a donor truck that has the same trans and 4wd box in it but can't find the time to swap that out either.
I never thought I was hard on transmissions. But I'll take a manual any day now. Easy to work on, easy to remove, don't overheat, only one clutch disc to deal with. :emotions122: I need to get my '75 shortbox 4x4 back on the road. It has a well built 355 with a sm465 in front of a 205 t-case. It was a project mud racer that I lost interest in. I didn't get too far to the "racing" mods other than the engine and clutch.
whtbronco
Winchester, VA
Wow, you really don't like those Avalanche seats. I miss the old flat bench seats, they were wonderful. Bucket seats are never quite wide enough for me. I used to insist on cloth seats, now I get in and out like an old man, sit down and then rotate, so vinyl or leather are easier to rotate on the slick surface.
I have pondered many times what I will do when the transmission in my Expedition needs work. I will do the replacement, it'll take me a week I'm sure. Will I do the rebuild is the question, it would be another few days at least. They don't look all that complicated. What I don't have is the experience to look at, for instance, the valve body and notice a single spot that is slightly worn and might not last long. It's easy to see something broken, bent, clutches worn etc.
This short video is interesting and potentially describes your issue. It also shows how relatively simple this transmission is.
R
Randy-IA
Nope, I really don't like those seats! I am a fabric seat type of guy. And the sad part is that seats are built in such a way these days that putting a quality seat cover on is barely better than flopping a blanket over it and using bungees to hold it in place.
You nailed it with the narrow part. This seat is designed for 150lb people with 32in waists. I understand they can't please everyone however. I know the foam in mine is collapsed so there's that. That leaves both side bolsters (and the console side bolster is larger from the factory which makes it worse) or some large lump from the mechanics under the foam to dig into the lower part of my gluteus maximus muscle at the hip joint. Not tremendously bad but longer trips of an hour or so leave me begging for relief. Not many options to add cushion because my head with the seat lowered all the way is only about three inches from the roof.
But, I digress ...
Since the expie has just over 250K miles on it I'd place a hefty wager that that is what is wrong with it. Very little notice (maybe two miles) and then all stop.
