22 Timberline. Global Window Up Does Not Work
Pancho258
McALLEN, Texas
Global window down works but not up. I checked through ForScan to see if up was turned off but it is not. Has anyone else experienced this and if you have can it be corrected without a visit to the service department?
Moderator
Did you add it via FORSCAN as an option, because it isn't there by default. If you did, there are settings that have to be added in more than just the APIM. That only adds it to the menu, but doesn't give you the function. In the F150's, it is in the PDM, and DDM where it also has to be enabled. Our 2020 did not have those modules, and the same things that were controlled by those are controlled by the BCM. As far as I know, it was never mapped out, as to where that code is. I never took the time, because it just wasn't worth it.
bb37
Member Relations Specialist
Indiana
I don't remember where I got the attached document. Maybe on Facebook. Interesting reading. Note that it may apply to Limiteds only. Use at your own risk.
  • 2024Exp-Forscan-GlobalWindowClose.pdf
Moderator
Yep, that code looks looks good. Should work on 22-24.
texsn95
Marine Corps
Houston
Excellent, just found out mine does the same thing, down works but not up, will try that code tomorrow.
