P013C CODE CHECK ENGINE 2013 5.4L 3V
JamaicaJoe
Oviedo FL
EDIT: Code is P013C
So today, one year and just over 2000 miles of ownership my new to me Expy with 119K miles suddenly flashed a Check Engine lamp while stopped at a light. I pulled over checked oil. Oil is fine, no overheating. It was a bit cold out maybe the 60's here in Florida. I turned around and went back home and got a different car.
I don't have a decent scanner, but have a ScanGuage and pulled up one code , the P013C which Googles to: O2 Sensor Slow Response - Rich to Lean. I think it is Bank 2 Sensor 2 downstream on passengers side?? Does this add up?
I have had no driveability problems at all except at times when idling at a light, a very slight sensation of the engine misfiring and the RPM falling almost imperceptibly, more a seat of the pants feeling that the engine stumbled and shook. I have considered that to be the AC compressor kicking in, though it was so random I could not prove that it was.
I could throw an O2 sensor at it and later find some other thing causing it, so I am throwing it out for the experts.
GlennSullivan
NY & FL
Pass side downstream sensor is what the code translates to, but it can also be other things besides the 02 sensor itself. I would change that sensor first and not go crazy looking for other things unless you see, feel or hear something else.
JamaicaJoe
JamaicaJoe
Oviedo FL
OK adding some info. I went out today and read the ScanGuage 2.
Still have a P013C and also some Freeze Frames. Here they are:
PID03 LOOP IS OPEN
PID04 LOD =52
PID05 WT = 75 deg F
PID0C RPM =1319
PID0D MPH = 42
PID0F IAT = 62 deg F
PID 10 GPH = 0.79, 0.57, 0.72 (this seems to be different every time i look so maybe live?)
PID 12 TPS = 19
I reset the failure codes and the light is out. Loop is Closed.
On my 01 I was able to read misfires in real time with Mode 6 commands provided by ScanGuage tech. However my 2013 apparently needs different commands. I mention this because there seems to be a small bit of subtle engine wobble at idle. Note it is cold, Florida cold right now 60's.
GlennSullivan
NY & FL
PID03 LOOP IS OPEN
PID04 LOD =52
PID05 WT = 75 deg F
PID0C RPM =1319
PID0D MPH = 42
PID 12 TPS = 19
A recent FordTechMakuloco video I watched shows him reading misfires on mode 6 using what I "think" is FORSCAN. Maybe that will work.
Here is the link, start at 4:50
JamaicaJoe
JamaicaJoe
Oviedo FL
Now I am seeing FORSCAN not available due to recent bank transaction bans to Russia. Is that true?
GlennSullivan
NY & FL
Joe
I've seen that info posted elsewhere and confirmed on FORSCAN website.
Try the 2 month free trial link below and see if it works for you. Others say it works fine and provides full functionality for a limited time, you can only do it twice, so be ready to tackle the problem when you license.
JamaicaJoe
JamaicaJoe
Oviedo FL
Well this is weird, almost exactly a year later. So I have a lot going on been kicking this down the road.
Sometime back in May I had this P013C code show up again and I reset it.
The past month I have not been driving at all because I had eye surgery around Dec 15. So the car has been sitting, I even put it on a charge.
Today I had to move it so ran down the block and happened to look at my SCANGUAGE II and there was a code P013C once again. No CEL though. So I looked at the PID's and it showed open loop, though the engine temp was in 180's, IAT in 90's (F) and the PID showed 41 MPH. So since I only moved the car to the street, not 41 MPH it must have been when driven weekly just before Dec 15 2025. So whatever this fault is happens every 6 months. Not going to panic. I have another issue, the ABS module which I have obtained NOS and that is going to local shop to program and install. At that time I will probably pay him change that 02 sensor, check for exhaust leaks etc.
JamaicaJoe
JamaicaJoe
Oviedo FL
Well it had a bad o2 sensor and I had all 4 of them replaced and it is running great. Replaced the ABS module with NOS part and the light show is gone. This 2013 has only a few issues to fix, the radio display (solder) and some blend door actuators acting up.
GlennSullivan
NY & FL
I ended up changing all 5 of my blend door actuators on my 2011 - 2 failed and did preemptive on the others 3 years ago at 60K miles. Haven't had any trouble since. Also changed the ABS module 4 years ago at 56K miles. Considering the low miles on this truck, it seems like these items fail with age and not use.
17expi
Mt Shasta Ca
Just get a real code reader and start there, they are cheap online. No need to go all crazy with the ******** etc.
