Spark plug recommendations
KSC 2019 XLT
DFW
I have a 2019 Expy XLT 4WD with about 77k miles and looking to replace the spark plugs. Looking for spark plug brands and models you all would recommend.
Left Coast Geek
Mid Left Coast
I don't remember if I did. the only spark plug gapping tool I have dates back to when I owned Volkswagens in the early 80s..
Dice Roll
Craps Table
NGK ruthenium off rockauto. Best deal I found. I changed mine at 30k for no reason, as they looked like they came out of a box. Zero wear. Gaps were all .028 across the board.
HILLY
Greenville, SC
Just did my plugs and boots Tuesday.
NGK Ruthenium’s that I got off Rock Auto. #90495. $8.70/ea
Motorcraft Ignition Coil Boot - WR6151. $7.36/ea
They were all pre gapped and even across the board - 0.032". I had used these in my previous Expedition and ran great & smooth. I’m only at 25k miles, but the truck is six years old now, plus I bought used so I’m trying to establish baseline for maintenance items.
ccssid
I feel like I was ripped off. Just paid $7.37 for the same boots at RockAuto about a week ago.
smp7032b
ny
Just put in NGK Ruthenium 1 Step Colder Spark Plugs HX LTR7BHX 95605 in 22 SPP
ZigZagFred
Air Force
Amarillo, Texas
Hi fellow Expys! The owner's manual for my 2019 Limited recommends spark change at 100,000 miles. Why are we changing our plugs so early?
Dice Roll
Craps Table
From what I’ve seen, guys running a tune are seeing higher wear. Mine on a stock tune had zero wear at 30k. Zilch.
You might reasonably get by without new boots like I did by changing before they get brittle. I put NGK ruthenium in and won’t revisit this for a loooooonnnnnggggg time.
Dice Roll
Craps Table
Not a bit. I’ve been doing cars as a hobby for thirty years. I feel the low end is a little sharper with the ruthenium plugs. Just my seat of the pants meter. Nothing scientific on that.
bb37
Member Relations Specialist
Indiana
Because they fail before Ford's recommended mileage.
I have personally experienced spark plug failure in a 2015 Expedition with 3.5 Ecoboost V6. Vehicle had about 70,000 miles on it. I tried to pass someone on a two-lane road that was slightly uphill. At full throttle, the engine began running rough and the check engine light flashed then became steady. After driving a few more miles, I tried another full throttle acceleration and again the engine ran rough with a flashing check engine light. The fix was to replace the plugs.
