Parking Brake Adjustment
djb8161
Seattle
Does anyone know the procedure for adjusting the parking brake. I fully engage the pedal but the rig still rolls in Park.
smo0othride
San Diego, CA
If you look under the drivers side of the truck, you will see a cable running parallel right beside the frame rail. Somewhere around the area at the back of the cab there will be an assembly connected to the cable which joings the cable into two seperate cables. If you look closely at the assembly, on the very end of the single cable there will be a nut, which when tightened will tighen all cables and the assembly. I recommend not tightening the nut too much, then you would place unneccesary tension on the cables.
D
djb8161
Seattle
Sounds pretty simple. Thanks for the instructions. I'll let you know how it turns out.
No members online now.
Landsbutter
