trav_27
I have a 98 Expedition with the 4.6 and just reciently I have noticed when going up a grade and it kicks into the highest gear it starts to cut in and out. like its starving for fuel. I just reciently changed the Thottle position sensor and cleaned out the throttle body, also changed the fuel filter. Also put a bottle of Chevron Techron fuel system cleaner in. It runs great no idle problem or problems when just cruising. just when going up a grade it does this. Also I cleaned the Mass air Flow sensor. If anyone can give me some advice, I would appreciate it. Also one other thing. I was greasing the front steering zerk fittings on the passenger side. I called the ford dealer, and they told me that there is only two on the vehicle, on the passenger side steering. I know that I overfilled one of them because grease starting seeping out of the sides of the seal. I also wanted to know if thats bad. Thank you
