Canadian Expy
Where do you guys buy your O2 sensor from?
but, should you change them if you are not having any check engine lights or engine runs good?
Found out today from Bosch Tech guy that the 15664 is different from the 15716. not just in length but heat range also. So I order 4 new O2's from Summit, the tech guy said at 100,000 you should change them out. He also said a 13117 would work but it has a long cable. Just tought I'd let you guys know.
which 4 did you actually get?
