I have 5 inches for my 35's. That's 3 inches of body lift, a 2 inch torsion crank in the front, and 2 inch coil spacers in the back. I know nothing about 2wd Expy's though. Someone will chime in.
i found the guy with the 7.5 in fabtech they say the crossmembers and everythin are the same so i might do that but will i need to do somethin different in the rear? and i wasnt sure if i need to extend the gas line and driveshaft etc can you answer tht
a 3" BL will bring a 2wd up to about the same height as a stock 4x4. a 2wd with a 3" BL might be able to clear some 32's with minor trimming, if any at all.
my buddies 99 2wd has 265/75r16 (31s) and thats the biggest he can run, my 00 eb 4x4 i ran 315/70R17 (34.5s) on my stock rim with only sway bar rub at full lock. i was running 285 KM2s on stock rim and i sat a full 5 inches taller withno lift
