05 EB Heater Problems
Tigerlax
Cape May, NJ
I am having an issue with the front heater on my 05 EB. The passenger side works perfectly, but the drivers side only blows cold. It has the dual control with digital display. This happens in all of the different vent settings from the defroster to the floor. The rear air/heat works fine with no issues. Any help or insight would be great.
T
Tigerlax
Cape May, NJ
I could be wrong but it sounds like a blend door. If you have heated and cooled seats, does your seat get hot?
I do not have the heated seats, just dual heat up front. Are there 2 blend doors, one for each side, on the EB's? If so is there a way of bypassing the drivers side one and hooking up both to the passenger controls, or is it just the same amount of work to fix the blend door?
ExpeditionAndy
Fort Wayne, Indiana
Normally you replace the motor assembly. If you have dual zones there are two blend doors. Hopefully one of the other guys will jump in. I think they are under the dash but not sure where.
