05 Expedition side view mirrors
luvmyexp05
Florida
Hello All! I am now thinking of replacing the original exterior side view mirrors with puddle light with one that has both the turning signal and puddle lights. Is the pin connector for the puddle light mirrors the same as for the turning signal/puddle light mirrors? If not, are there connectors that I can simply swap out to power the turning signal/puddle light on new mirrors?
Thank you!!
whtbronco
Winchester, VA
I'm sure the info is out there. I don't know for certain, but here's my thoughts. There is a good chance the wiring is in place. That said you may need to replace a portion of the wiring harness and/or change a setting in one of the computer modules to enable the integrated turn signal.
One thing you could do is find a salvage yard that will let you in and go see if they have an EB and compare the connector to yours or even buy the mirror head. It should be fairly cheap and see if it works.
