08 Front AC Quit, but Rear is Blowing Cold
Bloody-J
Lewisville, TX
Hello all. The last couple days, the front ac in my 08 EL started working intermittently. It would run for a while, then stop for 30 or so seconds, then start blowing again.
Today when I left work it wouldn't turn on at all. Interestingly, I can hear the HVAC box kicking on when I turn on the front controls, it just doesn't blow anything out the vents. The rear ac is working and blowing cold.
Seems like a relay? Any ideas?
Temple, Georgia
Check the fuse for that circuit with a meter or test light. Also check the connector to the blower motor resistor, they have a tendency to overheat and loose connection. It should be located next to the blower motor under the passenger dash.
Jefes_Shyt
