10mm(3/8”) Thick Thermal Sound Deadener Car Heat Shield Insulation Noise Reduce Mat
union pipewelder
Mississippi
Location Hillsboro OR
Free Shipping
$35.00 each
4 sheets available
Payments(Zelle, Venmo, Cash App-Lenvee Hemphill/662-347-0692)
10mm Thick Thermal Sound Deadener Car Heat Shield Insulation Noise Reduce Mat
Package include:
1Self-Adhesive Sound Deadening Mat
Specifications:
Material: Aluminum & Foam
Features: Car Heat / Sound Insulation
Size: 3’3”W x 4’ 10” L
Thickness: 3/8”(10mm)
Function: Car Sound Insulation
Temperature Rating: 200 Degrees Nominal
Outer Material: 99.4% Pure Polished Aluminum Reinforced Facing
Reinforced / Crush Resistant: Yes
Mildew & Mold Resistant: Yes
Water resistant: Yes
Non-toxic: Yes
Feature:
1. This product is 100% brand new.
2. Can be used for the entire interior of any vehicle including: floor panel, door, carpet under/seat, headliner/roof, trunk, trunk lid, firewall (internal side).
3. By reducing or suppressing the sound vibration of the metal plate, you can eliminate road noise.
4. Easy to install, suitable for various car models, simply trim pieces to fit, peel and place and hand roll to ensure good adhesion. No messy spray paint or adhesive is required to install this product.
5. This car insulation is used in many applications, such asmuscle cars, hot rods, light cruisers, imports, tuners, street rods, mouse rods, classic cars, racing cars, stock cars, old antique cars, pickups, trucks, low rider and many more. We even have customers using it on their SUVs, vans, RVs, luxury cars, campers, yachts, RVs and school buses.
The benefits of sound insulation:
Reduce road noise.
If you often drive on uneven roads or on noisy highways, sound insulation can bring you more comfort. It will reduce the noise of roads and other drivers. This will make your driving smoother and have the added benefit of better media listening.
Enhance the music.
Use sound insulation to make your radio clearer. You will no longer have to turn it up because of traffic noise. Not only is it good for music, but audio books and telephones will sound better, too.
Improve privacy.
If you don't want other people on the road to hear what you're listening to, the sound insulation prevents the noise from escaping. Sound insulation will help you.
Warm in winter and cool in summer
This car insulation will help reduce your interior temperature in the summer, keep you warm in the winter, reduce engine/tunnel/console.
Protect car paint
In summer, the temperature is too high, the engine runs at high speed and accelerates for a long time, and generates heat, which can easily cause the aging and fading of the car paint; the heat insulation pad can protect it.
Increase the life of the car
In summer, due to high temperature and long-term driving, it is easy to cause the cabin to heat up and cause a fire, which may seriously damage your car. Using heat insulation pads can extend the life of the car.
Installation:
Remove the door panels
Install the screws back in original place, it will easy be found when you mount, avoiding holes be covered
Please clean the surface you want to paste.
Make insulation materials and sheet metal firm fit, and play best adhesive, damping performance
Can be used for the entire interior of any vehicle including: floor panel, door, carpet under/seat, headliner/roof, trunk, trunk lid, firewall (internal side).and so on.
It is best not to repeatedly tear and paste during the successful installation process, otherwise the paste effect will be destroyed
