joeyg8
Got the truck and have no service records. What maintenance should be done at this milage. Some say don't change tranny fluid but it shift a little hard at times. What about diff fluid and transfer case
I bought one a few months ago with 127k and no records for service.
I started with cleaning out the throttle body and upper intake with B12 spray and added a can of B12 to the gas. I ran it for a few days and used the gas up and then did the normal seafoam treatment, adding some to oil and ingesting the rest into the vacuum system.
After that I did an oil change, trans fluid and filter (TC too), front diff, rear diff, and transfer case fluid. Also did a fuel filter change, pcv valve, replaced a few broken vacuum lines and also replaced the contents of the power steering reservoir. I just changed the oil again and sent a sample of the above oil in to Blackstone for analysis and hoping to hear from them today.
Since the initial maintenance I've done a power steering pump, fan clutch, new belt, tensioner and idler, rear wiper motor and replaced air filter with a K&N (filter only).
It runs and drives pretty well, but this last batch of work I really noticed just how bad the head gasket was leaking on the back passenger side. I also noticed that I'm missing several exhaust studs. Since I've already gotten into it with this truck and am "upside down" on value vs investment, I'm likely going to source a used engine to rebuild and replace mine and plan on keeping this thing around a while.
Other parts hopefully going in later this week will be a new thermostat and a set of shocks if I can decide on which ones to get.
