2" lift installed
NC-Expy
Apex, NC
Ok so I finally got my spacers installed, I got aftermarket keys so that I could lift the front a little more than the stock torsion bars would allow. It sits about level right now, I need to go in and get an alignment done as soon as possible. Only question is, how likely are these things to pop out?...
The lip for the particular spacers that I purchased is very thing (about 1/4 inch) and I feel like they could pop out going over a little speed bump? Am I wrong?
Another question, I know I've asked before; but what would be the biggest/widest tire I could fit? Since I want wider tires should I get wheel spacers? I'll post before/after pics soon.
walnuts4x4
Watertown, NY
if spacers are installed correctly you should have no problem with them... mine have been flexed every possible way and never moved... for tires with 2" lift probably a 33x12.5 tire cuz a 2" + 3" BL can fit 35s
NC-Expy
NC-Expy
Apex, NC
That sounds good. Idk how wide mine are but they definitely not any where near 12.5"
Remo
Hartford, CT
285 mm is about 11.25 in.
Got any pics with the new lift? I'd like to see.
I'm glad you got everything fixed, too.
NC-Expy
NC-Expy
Apex, NC
Sorry, let me upload them now. They might now be good though cause the fu**** sun down here is ridiculous right now.
NC-Expy
NC-Expy
Apex, NC
Before:
After:
Not that good of pictures I'll try to get some on flat land later. It's not THAT big of a difference in height, but I didn't get it lifted for the height, I got it lifted cause I want bigger tires. And with the aftermarket keys I got a little more lift out of it and that way I don't put as much stress on the truck.
Pic of the back:
I guess it really just depends on what angle you look at it. From some points of view it looks higher and other points of view it looks lower. Lol, idk!
NC-Expy
NC-Expy
Apex, NC
looks good! is it just me or does the rear look alittle lower then the front? either way it looks great!
I think the front is just a tiny bit lower than the back. I tried to make sure it was as level as possible. I need to go get a damn alignment done, I can't text and drive anymore! :nono:
2000eb
measure all four corners and get the level right before you get alignment
mudryder18
Auburn, AL
Nice NC, it looks very good. There is nothing wrong with the pics. Now you need to get some 305/65/r18 tires. (33.6x12x18) it will be exactly 1inch taller than your 285s and almost 1in. wider. I know it doesnt sound like much. But looks speak louder than words
JDMitchell
Fort Leonard Wood
Looks good, if I were you I would go with a 305/65/18. They will look beefier than the tires I have, and mine aren't exactly wimpy.
NC-Expy
NC-Expy
Apex, NC
Ahh, if only I could find some cheap ones! My tires in the 305/65/18 are $300+ each!
