2000 Eddie Bauer Expy is possessed (electrical issues)
Ristin
Idaho
2000 Expy EB 5.4l 4x4 154k miles.
In the 10 years I've owned this Expy, it has always had an electrical gremlim. If it sits for more than 2 weeks, the battery will get run down. I halfheartedly attempted to troubleshoot the parasitic drain but gave up and installed a battery tender that I plug in whenever the truck will be sitting. (I work out of town and my wife rarely drives it so it sits about 6 months out of the year.)
Couple months ago, I had been driving the Expy with no issues. Next morning I came out to use it and the battery was completely dead. Put the battery charger on and noticed all the accessories came on. Radio was playing, power windows were working, all with the ignition off and the key in my pocket. I got it running but every time I shut off the engine and removed the key, the accessories stayed on. The accessories stayed on for about four days so I plugged in the battery tender and just ignored it. After four days the accessories turned off and normal operation resumed.
The Expy has been operating normally until yesterday afternoon. I haven't driven the Expy for several days, but as I was walking out of my shop I could hear what sounded like a forced air heater. As I got closer to the Expy, I realized the Expy heater blower motor was running at full speed. The EATC display was flickering and the fan was on full speed. For kicks, I turned on the rear heat fan. The rear fan came on, the front front fan turned off and the EATC display turned off. Turned off the rear fan and the front fan came on again. Started the truck and all opreations returned to normal. Shut off the truck, removed the key and all was normal for a few seconds, then I heard clicking which turned into buzzing under the dash on the drivers side and the heater turned back on.
The weather was cold and snowy and I was not in the mood, so I disconnected the battery and walked away.
The floor is dry under the dash so I don't think I have water intrusion, but maybe?
Thoughts? and thanks for reading
Ristin
Ristin
Idaho
I found the buzzing relay. It's in a box mounted to the back side of the bracket that the OBD II port is mounted on. I'll need to take stuff apart to get to; I can't get my hand in to pull the cover off and I don't want to break the mounting bracket.
brhulen
Olympia, WA
I believe your issue is caused by a faulty GEm module and although you don't see any obvious signs of water intrusion I would almost guarantee you will find moisture where the GEM module plugs into the back of the fuse box. This is exactly what has happened to my 97 Expedition with the same symptoms.
You can try drying it out but it won't fix the water leak. Unfortunately the GEM modules are no longer available for Gen 1 Expeditions. You can use one from a similar F150 but it will not accomodate the rear windows defroster, washer and wiper. Your best bet will be to find one from a salvage yard. Good luck!
jayoo7
washington
I am having similar issues with my 02 expect my wipers and radio stopped working, my brake lights wont work unless my head lights are on, and recently my vents continue blowing after engine is off and key is removed, but they stop blowing once I turn the knob to the off position. I was able to locate the clicking sound to the blue fuse under the dash on the back side of the OB II port, I was able to get my small hands in there to pull it out and replace it. However a few days later back to square one.
JamaicaJoe
Oviedo FL
Another problem that can drain the battery is the rear wiper motor failing to park. When this happens the GEM module never goes to sleep and power continues to flow. Remove the fuse (under the hood) for the rear wiper circuit and don't put it back until you sort out the other gremlins.
