2003 5.4 EB Fuel Pump Relay
Bedrck47
Elizebethtown, PA
See attached prints
leave the jumper in place
next connect one lead of your volt meter to the red wire on C270a that is where one side of the jumper is
then connect the other lead to pin #12 on C270b its a light blue/orange wire
C270b is below C270k see print 11-01
also see print C270a which has pin layout for C270b
once meter is connected start the engine and read the voltage Post the result
  • C270a.pdf
CertusExpo
CertusExpo
Customizing trucks since I was 7 with my Legos
Fort Worth, TX
Bedrick,
May I have the first image/diagram (CJB) as a downloadable PDF attachment like C270a is? The text is sharper and way easier to read than the one that is showing.
Bedrck47
Elizebethtown, PA
I would have sent it if I had it 11-01 was just for reference That is why I stated that C270b is below C270k
The jumper was installed in C270a and C270k Now from that you should know where C270b is
CertusExpo
CertusExpo
Fort Worth, TX
Sorry Bedrck, I forgot I start an online class tonight so I didn't get a chance to perform the step you provided. I will get this info to you ASAP.
CertusExpo
CertusExpo
Fort Worth, TX
This morning:
From startup, had "Service Engine Soon" lit up and the attached codes were read by Torque.
FYI: I've been throwing this code off/on for a while now. Not sure if it's related to my fuel pump relay issue or not.
CertusExpo
CertusExpo
Fort Worth, TX
What are the potential side effects of long term use of the jumper in the fuse box?
Bedrck47
Elizebethtown, PA
Most likely will outlast you or I
All it does is jumper the contacts of the fuel pump relay It is fuse protected
When you remove the key or turn the key to off, all power is removed to the jumper
But I would replace either the relay or fuse box to be on a safer side.
CertusExpo
CertusExpo
Fort Worth, TX
I did replace the fuse box, no dice. As long as their aren't any long-term effects to the fuel pump or electrical system, I'd like to wire up a hidden kill switch in place of the jumper.
CertusExpo
CertusExpo
Fort Worth, TX
Used out of wrecked Expedition plus i made sure the wreck didn't beach the window or door to allow moisture to foul the fuse box.
Edit: I've purchased a replacement fuse to rebuild my original fuse box with.
