2003 passenger side front window problem
konny
glorida
Ok. I've searched but can't find this. Got this car used. Window Goes down fine but goes up really slow. The switch on the door only lowers it but won't try to raise it, I'm thinking it burnt out. I lubed the rails on either side and no help. Took the panel off and the glass seems to be set in the clips fine. After raising it and lowering a dozen times I notice the motor is too hot to touch. I notice that when it's all the way done and I start raising it up there is a big click that happens at the same spot when going up. Any ideas? Thx.
whtbronco
Winchester, VA
So 2 things there. It sounds like the window regulator, the assembly that the window bolts to and raises/lowers it, is hitting on something while it's going up. You'll have to pull the interior panel off again to find that. If this is the case something is likely out of place if there's no damage to door.
The thing is the switch. 99% chance it's just got some carbon build up. You can replace it and that will resolve it, but the truth is you can just scrape the carbon off the contact points inside the switch and it'll be good as new. Every time you hit a switch like for the locks or windows it arcs and creates a tiny bit of carbon. It's also possible that the plastic pins that actually push on the contacts are worn some, but with that mileage it's not too likely. I've cleaned my switches multiple times over the last 20yrs, and every other vehicle we've had with power windows. To disassemble the switch takes a couple flat head jewelers screwdrivers and some patience the first time. Slightly easier with 2 people.
LoneStarLoner
San Antonio,TX
Definitely check the regulator. Kept hearing a popping noise on my 03 and it wound up being broken and would struggle to raise properly.
Cleaning works well. I’ve cleaned mine several times by using some electronic contact cleaner and it brings them back to life. Works great for steering wheel controls that you think might have gone out as well. If you do have to replace a switch, the aftermarket Dorman brand actually worked surprisingly well and looks almost identical to stock.
baja2003
Los Cabos, BCS Mexico
Any idea on what stops the motor at the top or bottom? Or does it stop only when you let off the switch? My cables are all messed up, broken parts inside and mangled cables, but the motor appears fine and seems to run fine. I don't want to reuse the motor if it caused the problem by not stopping. Seems there should be a sensor somewhere to stop the window when it meets too much resistance, like somebody's arm or neck in the window?
Hamfisted
Ft Lauderdale
Just the resistance torque stops the motor, both up and down, and of course when you release the switch. If it's your driver window motor, and it's the original, you might consider replacing both the regulator and the motor just due to the age of the motor and the heavier use the driver window gets. In the winter time the driver motor will start to slow down noticeably as the motor ages.
I would recommend only using Motorcraft window regulators. If you use other brands sometimes you have door trim alignment issues.
Ford Expedition Drivers Door Window Regulator Online
