2004 DATC driver side blend door actuator failure write up
whtbronco
Winchester, VA
The driver side blend door actuator, the lower one, failed on my 2004 recently. The typical knocking noise was the telltale and impacting the driver side it was obvious which one. There’s excellent write-ups and videos on the passenger side already, which by the way is much easier to get to and replace. So I bought 2 actuators since they are the same part number, Motorcraft YH1865 / 1L2Z-19E616-AA, and I will replace the upper, for the passenger side at another time. I really could not find a whole lot of detail on replacing the driver side so I decided to write something up. This required a long ¼”ratchet and a borescope.
Ford says to remove the entire dash and the plenum to replace both actuators. That is not required for either, and doesn’t make sense for the upper actuator. For the lower actuator there’s a good bit of disassembly and 1 amazingly difficult to remove screw, that by the way is not going back in. It’s not likely possible without removing the dash. More on this later.
This took me a total of 13hrs including a trip 1.5hr to Home Depot and Lowes looking for a ratchet. I’m slow and often find other things to address and/or clean during a task that adds a more time.
To replace the driver side blend door actuator I removed the front seats, center console, pulled the carpet back to just behind the end of the rear floor HVAC ducts which also need to be removed. The kick panel trim and kick plates need to be removed on each side to get the carpet loose. It’s got 1 push in retainer under each front seat and pushes onto the duct under the dash.
The seats have four T55 bolts and multiple connectors. Remove the front bolts, move the seats forward like 70% of the travel and remove the rear bolts. Disconnect the battery, and then disconnect the electrical and airbag connectors for the seats. I just laid the 2nd row outer seats down and flipped the front seats backwards onto them. I also put a section of 2x6 on the 2nd row seats to keep the front seat mounting points from cutting into them.
The console is not hard to disassemble, but there are quite a few fasteners. Remove the rubber liner in the forward storage bin and remove the 7mm screw. Open the rear storage bin lid and pop the front top off, it just snaps on once the 7mm screw has been removed. Disconnect the power port at the front and the heated seat switch connectors at the rear. Open the 2nd row cup holders in the center console and remove the two 7mm screws. Remove the tow Phillips screws under the back of the lid, they hold the top of the rear panel on. The rear panel should pop off now, disconnect the electrical connectors. Remove the eight Phillips screws in the rear storage bin and pull it out. The main harness has a 10mm bolt that seats/unseats it, it should turn by hand to seat the connector during reassembly. If not check the pins, reseat it and try again. Remove the black 8mm bolt in the lower rear corner on each side and the 4 gold colored 7mm bolts inside that hold the side panels on. Now lift the side panels up and off the molded subframe, disconnect the power port connector on the passenger side panel. There’s two silver 8mm bolts holding the subframe to a bracket near the center and two 7mm black colored screws in the front of the subframe. The main harness has a push in retainer that needs to be pried out of the subframe and then the subframe can be removed.
There’s a plastic cover around the floor ducts you’ll see once the console is removed. It just uses three push in retainers, pry ‘em out. Remove the driver and passenger side lower dash vertical braces located at both sides of the transmission tunnel, three 8mm bolts each. There is one more bracket to remove now on the passenger side, the bracket you just removed bolted to it, and there’s just one 8mm bolt at each end of it. There are two push in retainers to pry out of the rear floor ducts and then they just pull off the front floor duct. There’s 4 gold colored 8mm screws holding the front floor duct to the plenum and three of the same 8mm screws holding the actuator to the plenum. On the driver side there’s one front and rear and another towards the rear on the passenger side. These three are easy, it’s the forth screw in the center towards the front/firewall that is near impossible to reach. This is a good time to remove the actuator connector. Now the fun begins. The remaining screw is accessible from the passenger side against the firewall about 9” from the side. I tried a 7” long ¼” flex head ratchet and an 8” 8mm offset wrench. I could get both on the bolt, but couldn’t do anything with it since it was finger tips only. My wife with her small hands tried to no avail. We decided another tool was needed and found a 12.5” locking flex head ¼” ratchet with a very thin/flat shaft at Home Depot, URL below. This worked, but still took some adjustment to get the low tooth count ratchet to grab another tooth, there was just too much play in the ratchet and the socket to bolt head. The 8mm socket had some play, a 5/16” was slightly smaller and with a strip of electrical tape on 1 of the 6 sides it was tight enough. I also had to lubricate the ratchet so it would swing back easier. Slow gentle movement didn’t work. Holding the ratchet up with left my left hand and very quickly swinging the ratchet back and forth would grab a tooth every couple passes. It took a few minutes, but we finally got the screw out. As noted I did not even attempt to reinstall this screw. Neither my wife nor I believe this would have been possible without my borescope/endoscope to see the screw and enable guidance for the tools. We pushed the lighted scope in on the driver side of the actuator for a decent view of the screw area. With the front floor duct loose pivot it towards the driver side, and remove the three 8mm screws that hold the actuator in. Swap the actuator and start reassembly.
Not required, but I removed the forward of the two steel brackets under the console subframe, two 15mm bolts, just ‘cuz I kept bumping it.
Good luck.
Ratchet, not an impressive tool, but it got the job done. https://www.gearwrench.com/all-tool...ick-release-locking-flex-slim-head-ratchet-12
Here’s several pics that might be helpful and in some I circled the bolt/screw locations.
whtbronco
whtbronco
Winchester, VA
Here's some diagnostic info that might help. However, I could not get the diag mode to initiate on mine. I did get the DTC from my OBDII scanner though. Code B2266 left side blend door circuit error.
More pics. The Passenger side dash bracket pic shows the actuator just forward of the bracket. I had a pic of the front floor duct and actuator, but I reckon I deleted it like an idiot.
whtbronco
whtbronco
Winchester, VA
A pic of that difficult to access screw and a truly terrible drawing of where screws/bolts go. I often do this for reassembly reference.
whtbronco
whtbronco
Winchester, VA
It worked for a week and it's failed again. Code 2266 is back. It worked all week, I disconnected the battery while I replaced the right front brake line and reseated the passenger side valve cover(waste of time as I expected). After about 36hrs I connected the battery and fired up the engine to check for leaks under full brake pressure. Everything seemed okay, but of course I didn't even think of trying the heat.
This morning it was blowing cold air on the driver side again. It's not popping this time, in fact using my ODBII scanner is just seems to spin forever when I select full hot or full cold on the blend door. When I hit stop on the scanner it shows 32.68% position. When I turn on the HVAC via the DATC head unit it's like the driver side actuator is making a very faint busy signal from a phone, haha. It provides a refreshing cold breeze driving to/from work that's for sure. I drive without shoes so at 14 degrees it's a dang cool breeze. I'll cover the floor duct before I go to work tomorrow.
I have yet to be able to get the DATC into diag mode despite numerous attempts. My scanner doesn't have the option to put into diag mode, seems I can do anything else though, ugh. Either I have not found the right combo to engage diag mode or my DATC head unit is faulty. This afternoon I tried every button combination, followed immediately my auto, three times, to no avail. Pulled the fuse just for kicks as well.
At the moment it's sitting with the battery disconnected again. I have another new Motorcraft actuator on hand, seems silly to swap it unless I can determine the cause though.
whtbronco
whtbronco
Winchester, VA
Disconnecting the battery did nothing to help as expected. Covering the floor duct did nothing to help with the cool blowing air, that surprised me a bit. I have found nothing else to try so Friday I'll swap the driver side actuator again. If that fails well I dunno.
I am growing tired of flimsy modern vehicles and the challenges they come with. There is not a single feature in modern vehicles that I can think of I would miss compared to a 70's dent side Ford. No computers, more than plenty of space working on them, every system is simple and easily accessed.
whtbronco
whtbronco
Winchester, VA
Maybe the next best step is the not so fun pinpoint test. I have about 1/2 the day Friday to get this working again before we get 2-3' of snow this weekend and it will be operational heat or not.
whtbronco
whtbronco
Winchester, VA
After running through the pin point tests and finding nothing out of spec, I verified the blend door was not hard to turn and didn't seem to have a blockage. I then messed with the temp setting to move the actuator back and forth while it was sitting on the transmission tunnel. The recently replaced actuator worked fine and I was getting very frustrated on the 4th or 5th pass it hit a spot and just kept spinning. Changing the temp caused it to keep spinning just like I heard when sending it commands with my OBDII scanner. I connected the new one and it made 7-8 passes without issue. I screwed the actuator into the plenum and tried again with the new actuator and it worked fine.
Today it only took me 6hrs. I had hoped to leave the seats in place, but the rear floor duct must be moved back a couple inches and that requires the front seats to be removed and the carpet pulled back. It's crazy, but the last 7 screws took me an hour to install, I had lost all feeling in my hands and that makes it crazy difficult to work with small screws. It's quite comical to watch me do stuff like this when my hands go numb.
One thing to note I was able to disconnect, probe for pinpoint tests and reconnect the DATC head unit connectors with only the console removed so the gauge cluster trim did not need to be removed.
So it appears that for some reason a brand new Motorcraft actuator failed after 5 days of use. The battery was disconnected for about 36hrs and it failed on the next use. So I dunno. There's another new Motorcraft actuator in there, we'll see if it lasts more than a week.
whtbronco
whtbronco
Winchester, VA
I finally got the DATC into diag mode. I had to hold the Off and Floor buttons down for 10+ seconds and then immediately press the Auto button. By immediately I mean I could not use the same hand. The moment I started releasing the Off and Floor buttons I pressed the Auto button with my other hand already in place. That did the trick and was repeatable.
What it did was move the blend doors, display the fan speed in an ascending pattern, this repeated a few times and then every icon on the display lit up, as seen here:
kep5niner
Army
MO
Whtbronco, your perseverance is to be admired. Now that you’ve successfully accessed the diag mode on the DATC, just remember to exit the diag mode appropriately in order to recalibrate your mode / blend door actuators.
I tackled both the passenger and driver side on my project ‘03 (and the rear). Ultimately ended up having to source another DATC ($30 on eBay). Also had to replace the optical sensor on the dash.
That got the system working 100%. Loved that truck and really enjoyed it for the short time I had it, completing the restoration. The new owner is completely happy….my dad said “if you EVER want to sell the truck, call me first.” It serves him well! And I REALLY enjoy the replacement Navigator.
whtbronco
whtbronco
Winchester, VA
Yep, exiting the diag mode was the easy part. I was pretty amazed at how much trouble it gave me to get it into diag mode. It's been working fine for 7 weeks now thankfully.
I am a stubborn SOB and I will just beat the heck out of something until I figure it out.
@kep5niner You'll understand the differences better than many others. I spent 8 days driving a 2024 Expedition Limited. I like fixing mine much better now. I liked only one single thing on the new one, the steering wheel. The thicker steering wheel hurt my hands a bit less to hold.
Kenerator
CA
Great job whtbronco! My mechanic buddy at a Ford dealership says it's a $2,400 if nothing else gets broken during the job. I am NOT looking forward to doing this to mine.
whtbronco
whtbronco
Winchester, VA
It's not fun, but it's also not terrible. Take your time, expect it to take pretty much a full day and make sure you have a long thin ratchet or ratchet wrench to get the front screw out. Oh and make sure you keep track of where all the screws go in the console and such as you disassemble.
$2400, yikes.
