Hi all,
Looking for insight on fixing the A/C in our '19 Exp to see if I can figure out what I've missed before I reach out to a repair shop...
In the front: cold air IS being generated and the blower motor ramps up and down with the fan speed dial. The problem is, about 3/4 of the time it refuses to let the cold air into the cabin. You can hear the blower motor blowing against what sounds like a closed vent somewhere beneath/behind the dash. I replaced two front blend door actuators, one on the driver side to the right of the gas pedal, and one on the passenger side. My understanding is these adjust whether the air comes from feet, dash, or defrost vents. I saw the 3rd gen Expeditions had a third actuator but couldn't find it. I'm thinking this one might control whether the air is allowed in from the A/C or heater systems. I tore the dash apart looking for it but couldn't find it. I'm assuming there must be a third actuator somewhere, I just don't know where. Appreciate any help finding it!
In the rear: cold air is NOT being generated. The actuator works (can switch between roof vents and foot vents) and the temperature DOES adjust. Hot gets hot, but cold only goes down to ambient temperature. I'm thinking it might have lost refrigerant, but I'm curious if there's something obvious I can try before taking that to get looked at. I've gotta tear the whole back right apart to get to it, again I appreciate any insight on what I might be missing before I go down that rabbit hole.
We live in San Antonio and the weather's already getting to the point where I'll have to start throwing money at it if I can't figure out what I've missed. Again, appreciate any ideas/insights!
