2004 EB Navigation
EddieArc
Columbus, Ohio
just bought a 2004 EB with factory navigation, found some Navigation disks but the unit does not read them, they are 3V from Navteq...do I need some type of set up,disk...the unit plays music cds fine..
John Christopher
CT
I have a 2003 EB with navigation and my CT disc does not read. All of the others work. I bought a new set of discs and it works fine now. I would consider selling my other set if your interested.
John Christopher
CT
I have the original version that came with the truck. There is no setup disc that I know of
Do any of your discs read? If not there may be a problem with the system. You can try running
a CD cleaner, with the little brush on it, through the system. Good luck.
EddieArc
EddieArc
Columbus, Ohio
Thanks for the info, I’ll try a cd cleaner, music cds play fine, but none of the navigation disks work. Btw..how much do you want for the set you have?
John Christopher
CT
I would take $75 for the set. Believe it or not a new set which is the same as ours is $200.
I've seen individual discs sell for $50. It's nuts. I hope the cleaner works for you.
John Christopher
CT
Let me know if the cleaning solves the problem. Thanks
