65comet
So, I was doing my cam phasers and dropped a screw down into the oil pan, d'oh! Anyway, I had wanted to drop the oil pan before that had happened to make sure the pickup was clean, just doing it a little sooner. I'm having a hell of a time with the cross member bolts. Maybe my impact is getting old, but it just rattles away and doesn't budge them. I PB blasted them, wire brushed the threads till they looked new and heated up the nuts some. Put a 18" ratchet on the bolt head with the handle against the ground and a 18" breaker bar on the nut with a 2 foot steel pipe on that and the nuts have started moving if I put both arms into it. My problem now is with each small turn, the ratchet falls off the bolt since both hands have to be on the breaker bar and I have no help to hold it for me until Saturday. I tried wrapping a wire around it, but it puts it at an angle and pops off. What have others done to hold a wrench you can't hold with your hand?
