2009 Issues
jawalla3
houston
I have had an issue with the engine dying when I come to a stop or slow down. It doesn't happen all the time, more often when the gas level is past half a tank. I have taken it to 2 shops and they couldn't figure it out. I have O2 sensors that I should replace. Is there anything I am missing? Am I better replacing with a newer one? also it has 109,000 miles and i have replaced the spark plugs.
Drew
mjp2
Howell, NJ
Engine dying when letting off the throttle is a sign that your fuel pump is failing. The engine likely cranks slightly longer than normal when starting. Hook up a fuel pressure gauge and take a reading.
From what I've read it should be right around 35psi key on/engine off.
