2012 5.4 triton (Gator), light misfire (?) vibration at idle
Adieu
SoCal
No check engine light
***** coolant and probably wrong oil (just bought it)
131k mi (allegedly) --- bought it from some pretty shady Syrian limo company, so who knows
Signs of recent servicing under hood -- all coolant hooses newish and still have clean Motorcraft stickers on em, but the coolant itself is pale blue crap with some hard water salts-looking sediment in it
Occasional slight hesitation pressing accelerator, but otherwise runs fine. MPGs seem correct, fluctuate 14-17 mpg (4x4, EL length)
Should I just change oil and backflush the coolant system, then put in proper gold coolant to start? Or redo the spark plugs immediately as well? Thermostat right away too, or never mind that?
A
Adieu
SoCal
What else? Injector cleaner? Double oil change/oil flush?
Trainmaster
Old School Member
Rockaway Beach, NY
The oil and coolant has nothing to do with it running rough. Fix the rough idle first. Find someone with a computer who can diagnose what cylinder is missing, then check the coil, plug and injector in that order. Or just pull a spark plug and see how it looks. They may have never been changed.
If you opt to change the plugs, go with new Motorcraft boots also.
You may also want to check the block for a head gasket leak.
A used Syrian Uber car? Good grief.
A
Adieu
SoCal
Not Uber, these guys were too dumb to make that work for em ("my guy wait hour, he no get call, vi decide Uber suck")
Meh who cares, it's a familiar engine that I know how to work on. As well as any number of mechanics, should I ever find something I can't figure out
Ford engine, ford pricing
D Hook
Army
Omaha, NE
If it's a real rough idle, you mayh want to check the the VCT (Variable Cam Timing) solenoids. Easy to change both. Access is through openings on the valve covers towards the front of engine. Do a search for it on this website and you'll find videos showing how-to. Causes misfiring at idle. Wife's expy has the same issue right now. Controls oil flow to cam phasers and when the VCTs start to fail, it usually results in rough idle at stop lights. Starts to sound like a desiel.
Plati
Took me months to figure out ... Navigator.
1955moose
Whatdya think Ford built Lincoln's down in the Louisiana bayou! Actually I think Ford does build stuff down there!
1955moose
Now you know why working on a Navigator is such a Croc! Ha Ha!
coolzzy
Idaho
VCTs on the 08+ Tritons were no longer easily accessible as the valve covers were redesigned when they went away from the 2 piece spark plug. They now require the valve cover to be removed. Not terrible, but not nearly as easy to change. With those miles, I would do spark plugs and coil packs, the coil packs are cheap and a common point of rough idle or miss on acceleration.
A
Adieu
SoCal
Actually.... unless you go with China coils, coilpacks are pretty dang pricey
