Remove the inside fuse cover in the passenger side kick panel, it will have a bar code with a tag with 5 numbers and a letter. All you need is the numbers.
Also, if you have two keys, there is a procedure, where you put in the first, turn on and then off. Remove 1st key and then do the same with the 2nd key. The Door code will appear on-screen for a few moments. There is a youtube video on it, so if anyone is curious, look it up.
