2016 front AC blower motor only runs on high
BogueSound
Bogue, NC
The local dealership did the recalls to my master cylinder and front blower motor. On the master cylinder they didn't get something about the install correctly and I would have to jam on the brakes to get cruise to disengage. The service rep I talked to grumbled about the part that was broken wasn't part of the recall but with it being so obviously not working immediately after their job, they are fixing that.
And then about a month after the front blower motor now only runs on high. They are claiming it is the AC control module and want $1150 to fix that. I've always gotten scammy vibes from them but it looks like most of the threads here with blower motor resistor issues are related to slow or intermittent motors so perhaps it is just a coincidence...after all, this thing is a giant steaming turd and will without question be the last Ford that I or anyone in my lineage ever owns.
If it is the control module, I think it's just popping the front controls off and unplugging old and plugging in new?
99WhiteC5Coupe
There are lots of threads and posts on this forum about this issue. Do a search and some reading.
Replace the blower motor control, which is mounted on the HVAC case - not on the dash. Also replace the wiring connecter, as there is a TSB issued by Ford regarding the connector.
I have posted several times a link to a YouTube video on how to replace them. It is easy to replace and the cost of $1,150 is absurd.
Edit: Information in post #2: https://www.expeditionforum.com/threads/2017-recall.55502/#post-506636
99WhiteC5Coupe
I guess I should have been a little clearer. They are saying it is the HVAC control module, which I believe would be this https://www.fordpartsgiant.com/parts/ford-control_fl1z-19980-a.html
I haven't talked to them yet to ask that troubleshooting they took to claim this is it. Everything else works about the AC, can change vent location, AC on/off, heat, just can't change speed.
I did misunderstand what you posted. I do not know if the control part your referenced is a plug-and-play item.
Even if you pay list price for the part - the dealership is charging you a lot of labor to remove a dash bezel, and change the part.
Hamfisted
Ft Lauderdale
More likely they're talking about the blower motor control module, which is their new fancy term for the speed resistor. It's located behind the glove box. Remove the glove box and inspect it, and the harness it's plugged into. This plug is a common failure point and easily replaced. Look for burned or melted plastic in the plug. Dorman makes a repair kit that includes a new "speed control module" and plug.
2016 Expedition Blower Speed Control Module at Rock Auto
Ryan L
Houston
Having replaced my resistor twice (non-OEM, then OEM), connector plug (aftermarket pigtail), and blower motor on my 2016 Limited, my guess is your resistor is failing. If the plug is melted, repair with an aftermarket pigtail. I recommend only OEM for the resistor, though, as aftermarket resistors do not last.
B
BogueSound
Bogue, NC
Last thing to add, for now. I thought when I was playing with it earlier that turning off the entire HVAC system would turn off the blower, but that isn't the case. Even with HVAC off it still continues to run.
I also talked to the service rep, who I don't fully trust, and asked how they diagnosed and what they checked, and he gave me boilerplate about hooking up to the computer and then following the steps.
Does the resistor have 12v in it such that even with the AC off it could still power the blower if the connector is melted enough shorting wires? Hard for me to imagine the central HVAC controller would work for everything except blower speed AND not stop the blower when it was turned off.
rsupak
Just replaced my resistor Friday as the blower in my would spin up and down on any setting beside high.
Steve Tanner
Arizona
Depends on which system you have. On mine (2017 EL XLT) it's not a resistor, it's some kind of PWM speed control managed by the HVAC module. It has an aluminum heatsink and 4 wires - +12, -12, control, and Output (to blower motor). If it failed internally it certainly could run the blower on high all the time. Ford calls it the "Blower Motor Control Module", Motorcraft YH2060 / BL3Z19E624B. It looks like this:
As others mentioned, it is easy to get to if you remove the glove box, which is only a few screws. Unplug the connector and it comes out with 2 screws. If anything you can visually verify that you have this type of module. I replaced mine when I replaced the evaporator, along with the pigtail. Both had significant discoloring and plastic distortion due to the pigtail problem also mentioned above. Here is what it looks like installed (dashboard removed shown during reassembly here, but you can see where it is):
