I recently purchased a 2003 EB with 4wd. I noticed while looking under the hood a vacuum line that appeared to be disconnected. When I traced the line I found it is the vent vacuum line that is running from the wheel hub. One end is attached to the wheel hub as it should be, but the other end is just laying loose in the engine compartment. Is it supposed to be attached to something? It looks like it was knocked loose as some point and never reattached. As far as I'm aware my 4wd is working correctly.
