I converted the suspension because I had previously owned a Lincoln Mark VIII. I was meticulous about maintaining that system and very active in that car community. Despite this, it would still failing at the most inopportune times.
The moment i detected a leak in a coil spring on the Navigator, I yanked the system for a Monroe coil spring conversion, thinking I'd never have to worry about it again.
Unfortunately, Monroe was selling weak coils, so years later, they did send me a stronger set of much stronger replacement springs underwarranty
I just replaced the control arms on my Navigator.
When i checked, I realized I bought the set that DID NOT have air suspension.
When doing this, I would suggest you also purchase the Caster/Camber Adjusting Kit and make sure you tell the alignment shop that you've done so. Since it's not supposed to be adjustable without this part, they usually don't even check it.
