98eb5.4
need to top up so looked into it
98 owners manual from ford shows
on the above, looks like mercon v replaces mercon
http://www.aftermarketnews.com/ford-announces-new-replacement-specs-for-mercon-atf/
from info i've come across so far, my 98/5.4/4x4 has the 4r100, prob calls for merconV,
pretty sure the 4r100 was introduced or came on some (prob later) 98 setups, tho not showing in a current ford owners manual
edit - the 4r100 is in the 98 ford service manual
Transmission fluid
Motorcraft MERCONt V ATF
4R70W 13.1L (13.9 quarts)
Motorcraft MERCON ATF
E4OD (4 x 2) 15.0L (15.9 quarts)
E4OD (4 x 4) 15.5L (16.4 quarts)
