A/C Question
dlose9
PA
I have a 1997 eddie bauer expedition and my A/C doesn't work. the compressor dosen't kick on when I turn the switch on in the dash. I have tryed to jump the sensors and I tryed to jump the clutch and the compressor still dosen't kick on. The sensor wires are confusing so i'm not sure if I did it right. My next guess will be that the compessor is bad and it needs replaced. Does any one have any other ideas of has any experience with this. I am hoping for an easy fix...lol also...The system is full of refrigerant?
KWT2000
NINE MILE FALLS
the pressure sensor on top of the dryer is only 2 wires jump one to the other if it comes on its a bad switch if not its a bad compressor clutch or a wiring fault
D
dlose9
PA
I tried that and nothing happened.... I also tryed to give the compressor power and nothing happened. Thanks for the advice
KWT2000
NINE MILE FALLS
anytime... if you can spin the compressor by hand... you can buy a clutch rebuild kit should save ya some cash
joezek
psl, FL
Did you check the fuses, and also the relays? There's usually a 30 amp fuse, and also a relay in an under the hood fuse box. Most of the time the relays are all lined up and the same part number. You can swap two of the relays that are the same part # for troubleshooting.
