A few leveling questions
LastExpo2000
LastExpo2000
Corpus Christi, TX
Right now I have 265/70/17 and 17" stock rims
I was going to upgrade to 1.25 or 1.50 spacers with 305/70/17 tires if they would fit
walnuts4x4
Watertown, NY
those tires should fit without the spacers or lift... cuz you can fit 33s on a stock 4x4.... and 305s are a big 31... so the spacers should push out the tire from the frame but then you would have to worry about the lower valance on the bumper...
LastExpo2000
LastExpo2000
Corpus Christi, TX
What is the lower valance exactly?
walnuts4x4
Watertown, NY
the bottom plastic skirt that goes on the bottom of the bumper... if you get rubbing you can trim it away were the tires rub... I trimmed 1/2" off mine and no rubbing now
panda24619
San Diego
youll fit with no spacers or lift. but if your going threw all that trouble of a lift get a little bigger tire. use the calculator and itll help you out a lot.
walnuts4x4
Watertown, NY
yeah I would look into tires first because with just doing a TT (torsion twist/crank) a 4x4 can fit 285/75r16s which are a hair shy of a 33" tire.... so with a TT and spacers any 33" or smaller will fit without spacers
LastExpo2000
LastExpo2000
Corpus Christi, TX
I have 17" stock rims. I was going to go with spacers to get a wider look, like solisomos (might have butchered the name, I apologize). Also the Rear spacers will keep my green tortoise from dragging its rear
walnuts4x4
Watertown, NY
if you do a rear coil spacer and a TT I would go with a tire around 33" tall... it will also be wider than stock and the spacers will push the tires out a bit....
NC-Expy
Apex, NC
yeah like panda said, you'll fit about a 33" tire even w/o the torsion twist. I'm running a 32.6 inch tire (285/65/18) with stock suspension. I'm going to upgrade the suspension with cranking the stock torsion bars and adding a set of 2" coil spacers in the back. Hopefully I'll be able to fit a 34" tire or bigger.
mudryder18
Auburn, AL
Since you have 17in. rims i would go with 305/70/r17 (34x12x17). It will fill the wheel wells perfectly with 2in. spacers and cranked torsion bars. And you should have minimal rubbing if not none.
No members online now.
Landsbutter
