shadow460
This is the third compressor that's gone bad in my '98 Expedition. The one that was on it was bad when I got it. I took it to a mechanic to have a new one installed; they put a NAPA Cold Power and it lasted a little over two years.
I replaced it myself with a rebuilt Murray unit that lasted four months. Neither of us replaced the dryers although I did pull a vacuum for about 90 minutes and I weighed in exactly 62 ounces of R134a. I also have the "old" 134a in a recovery tank.
The first two compressors leaked around the shaft seals. The one I put on gets pressures of 45 and 165 which won't cool the vehicle.
I don't know if the compressor I put on failed from acid or if it wasn't rebuilt correctly. I know from experience how acid kills residential AC compressors: it destroys the electrical part inside the compressor. Well, here we don't have anything electric in the compressor at all to destroy.
My question is what exactly does acid do to a motor vehicle compressor? With no windings to attack (unless you drive a hybrid), what's left??
