after market 'tow package'
erictheall
Birmingham, AL
Greetings, all!
I recently bought a used '08 Expy Limited 4x2. At the time I purchased, I was under the impression that the vehicle included the tow package. I now know that, while it does have a class IV hitch and 4-pin connector, it does not have the tow package. I'm in the process of collecting info to take back to the dealer.
So here's the question... I know I need a brake controller and 7-pin connector. I also know I need a trans cooler. I have heard mixed opinions regarding an upgraded radiator. Some folks say get it, others say no. Keep in mind that this is a 6 week, visit-20-national-parks trip... crossing the Rockies twice in June/July.
Would it be sily to NOT upgrade the radiator?
Thanks in advance,
Eric
docraymund
philippines
You definitely need to upgrade the radiator to a bigger one and install a high capacity oil filter.
Bedrck47
Elizebethtown, PA
Being you are taking it back to the dealer and you didn't say if it was a Ford dealer.
I would take it to a Ford dealer and ask for a quote to have the Expy upgraded to the heavy duty tow package. Once you have a quote then decide if you want them to do the upgrade or have it done elsewhere or by yourself
Ask for a break-down of all that is required to do the upgrade. You may also want to consider buying a good brake controller as you may find it will be less cost than a dealer Look at a good Tekonsha Trailer Brake Controller - 1 to 4 Axles - Proportional Controler
What will you be towing and also what is the dry and gross weights of the rig.
ManUpOrShutUp
PA
The heavy duty trailer tow package became standard on the Limited in 2009, so you just missed it by a year. I would upgrade the radiator.
