BigDaddy 747
The following was copied from the 2007 ford service manual this will hopefully give you some information for the 2009 expy
All climate controlled seats are inoperative
Fuse
Circuitry
MS-CAN network communication fault
CCSM
EATC module
VERIFY battery junction box (BJB) fuse 8 (40A) is OK. If OK, CARRY OUT the Data Links Diagnostics test using a scan tool and verify network communication of the EATC and CCSM. REFER to Section 418-00 to diagnose a module communication or network concern. If OK, CARRY OUT the CCSM on-demand self test and retrieve any DTCs. If any DTC is present, REFER to the Climate Controlled Seat Module (CCSM) Diagnostic Trouble Code (DTC) Chart. CHECK the climate control system for correct operation. REFER to Section 412-00 for diagnosis of the EATC or climate control system. If OK, INSTALL a new CCSM and CARRY OUT programmable module installation (PMI). REFER to Climate Controlled Seat Module in this section.
A single climate controlled seat is inoperative/does not operate correctly
Circuitry
EATC module
CCSM
NOTE: If a fault occurs setting a DTC specific to only one climate controlled seat, the CCSM will disable only the affected seat outputs and allow the other seat to remain operational. CHECK for DTCs specific to the affected climate controlled seat and, if a DTC is present, REFER to the Climate Controlled Seat Module (CCSM) Diagnostic Trouble Code (DTC) Chart.
Go To Pinpoint Test Q .
A single climate controlled seat does not operate correctly — poor or intermittent cooling/heating
Excessive sun-load or extreme cabin temperatures
Incorrectly installed thermo-electric device (TED), manifold or plenum
Airflow blockage
TED
CCSM
CARRY OUT the CCSM on-demand self test and retrieve any DTCs. If any DTC is present, REFER to the Climate Controlled Seat Module (CCSM) Diagnostic Trouble Code (DTC) Chart. If no DTC is present, CHECK the affected seat cushion or backrest for correct installation of the climate controlled seat components (TED, manifold, plenum, air ducts and foam pad) and REPAIR as needed. If OK, CHECK for airflow restrictions (TED inlets and outlets, TED-to-manifold or plenum connections, filters and ducts) and REPAIR as needed. CHECK the TED cooling performance on the affected seat and VERIFY the system is operating correctly. REFER to Component Test — Thermo-Electric Device (TED) Cooling Performance in this section. RETEST the system for normal operation.
A single climate controlled seat does not operate correctly — exhibits poor airflow or performance
Airflow blockage
Disconnected air duct
CARRY OUT the CCSM on-demand self test and retrieve any DTCs. If any DTC is present, REFER to the Climate Controlled Seat Module (CCSM) Diagnostic Trouble Code (DTC) Chart. If no DTC is present, CHECK the affected seat cushion or backrest for correct installation of the climate controlled seat components (TED, manifold, plenum, air ducts and foam pad) and REPAIR as needed. If OK, CHECK for airflow restrictions (TED inlets and outlets, TED-to-manifold or plenum connections, filters and ducts) and REPAIR as needed. RETEST the system for normal operation
