Almost crashed
Tonka
Columbus,Ohio
Driving down freeway yesterday, a bunch of thick white smoke started blowing out of exhaust. I get off the exit the truck loses control and spins out sideways I end up going up a ditch thank God no other cars where at my exit this day because that exit is usually packed, and I did not flip over. The engine was smoking like crazy. I smelled coolant coming out too, and when it got up on the tow truck it was weird because the rear passenger tire was dripping wet too!! So Idk its getting checked out it was a crazy experience though.
DeafBringer
Washington
yeah if it was the rear passenger side, could be that the rear heater hose burst like Cyclone mentioned. If that's the case, it would have dumped coolant in the path of the rear passenger tire. Freshly dumped coolant on a road surface is slicker than snot. That may have caused the spinout?
Tonka
Tonka
Columbus,Ohio
Got y’all appreciate the help cuz it was definitely wet. Would it cause the engine to smoke too and for smoke to come out exhaust pipes or would that be something separate?
JamaicaJoe
Oviedo FL
Sounds like the "smoke" was the rear heater hose blowing steam and that the hot wet tire spun you out. Weird, but maybe no engine problem if that is the case. Scary though. What year and mileage?
Medic 1938
New Jersey
Stem coming out of the exhaust pipe …. head gasket
JamaicaJoe
Oviedo FL
That would be bad. But the exhaust is rearward of the tire, so would not explain losing control and would not expect huge volume of water to get past the catalytic convertor. Then again the engine could have locked up the wheels and the system steamed out all it could.
cekkk
SoCal
I'll be following this. My DW has a '13 King Ranch with only 55k and she won't part with it. Doesn't want all the techy stuff my Lincoln has.
