TactialMonkey
So I went to the junk yard the other day Saturday it was to get a new heater and the donor truck was smashed on the inside of the fire wall so that sucked 3 hours wasted but not the point, on the f150s is the frame from expy to f150 the same? in a perfect theory I could just take the leaf springs off a f150 and throw them on the expy with the mounts and all off the pick up and then as to the front end I was looking at the superdutys and the front leaf mounts are like either connected to the tow hook or behind it and the rear mount is on the frame rail so I was thinking that if the frames from the excursion are probably my best bet for donor leaf springs because it’s the same idea as an espy just bigger so I’m basically trying to take the springs and axles off an excursion and seem them in to a lighter duty truck and I also learned that the BW 4406 is not compatible with the ZF5 so I need a BW 4407 which is the same bolt pattern I believe but I’m not sure
