Hey folks. We bought our 2010 Expy in 2012 from a dealer in Little Rock. They paid to have the actuator replaced for the passenger side because it would not blow cold air in the 100+ degree weather we had then. Now, this year, my driver side HEAT does not work. I have read multiple threads and there are several different responses. Some said that there are 2 actuators, one for each side, and others said there was only the one actuator. My Limited has dual climate control, so I will have to assume that there is 1 for each side. I have yet to find where the driver's side actuator is. I did remove the guage cluster and did not find anything back there. Have removed the radio and found the actuator that I think is for the passenger side. Can clearly see the actuator that changes from floor to mid to defrost and it functions properly. Just no heat on driver side. Wife hates driving it when it is cold outside. I need to get it fixed, because "if momma ain't happy, ain't nobody happy" if you get my drift. Any help appreciated.
I was successful in replacing the driver side Blend Door Actuator. I went to the local Ford dealership and asked for a printout on the AC stuff under the dash. The printout they gave me did NOT include the driver side blend door actuator. So, I asked for a printout of the 2010 F150 AC stuff. Lo and behold, there it was, on the bottom of the printout, just mere millimeters from the floor.
I also found a video of an F150 driver side actuator being replaced. It can be found here: https://www.youtube.com/watch?v=p5xvlbiaxF4
I did not use the all the exact instructions, but you can get the idea from watching the video. It really wasn't too terribly difficult. I did have to cut the top of the duct work that goes to the back of the truck, just to get the new motor put back in, but it did not affect the heating/cooling in the truck as I only cut the edge of the duct work. Also, as stated in the video, the electrical connector is a PITA to reconnect.
You should be able to accomplish this with a little help. Me and my buddy did it in about an hour and 15.
2003XLT. I reached in and unplugged both of them. Problem solved.This is a great thread... Anyone tackle the rear actuators yet?
