Can’t find correct lift
Aggieredneck12
does anyone know what kind of lift can be run on a 2019 platinum edition? The only lift I find is the readylift 3/2. It states it doesn’t work on platinums due to the air suspension in rear. Does anyone have any advise? I know I can fit 35’s by shaving the auto running boards a hair if need be but I can’t find a lift that will work for the suspension.
mattastic13
Corpus Christi, Tx
I am fairly positive that the ReadyLift is the ONLY lift currently available for the new gens. Is the air suspension the same as CCD? I think people are creating brackets and it's working. There are several threads about it.
16plati
VA
Readylift is the way to go. There is no true suspension lift for any of the newer expeditions. You can get bilstein adjustables from F-150 and put them up front with spacers in the rear
