I need some cargo tie downs to hold a mini-golf cart, 305# in place in my 2017 Expedition. I'm thinking I only need to keep it from going forward so I could put two on the channel between the closed hatch and the carpeted area where the ribbed plastic is. It probably covers a closed metal channel, if I guess right.
So, two possibilities are some trailer bed d-ring assemblies but this would require cutting the plastic and screwing them to the metal channel. Another thought is d-rings attached to simple metal pieces with screw/bolt holes in them and put them in with sheet metal screws when I need them and unscrew them when I don't.
My preferred idea, though, would be permanent bolt receivers in this channel that are either threaded or accept a d-ring attached to a pin with ears that go down in this receiver then turn 90 degrees to lock in place. This or the previous idea should only require a hole be drilled.
Again, I am assuming that is a hollow channel under that plastic piece. I can get by without forward tie downs although I would like them. But I can use blocks behind the rear wheels and ratchet straps attached to the d-rings and secure the rear wheels between the two.
Any thoughts on these or other means to my ends? I don't know where to find the female receptacles for my favored idea. I'll look at Harbor Freight, Northern Equipment, trailer manufacturers and truck stops. I haven't found anything online.
