climate control seats
danclow
alberta
2004 ford expedition 5.4 l eddie bauer, when I push either the air conditioning or the heat the light comes on for a few seconds then goes off, I checked continuity on the elements and I have continuity, is there anything else I can check, could it be a module, does anyone know what kind of resisitance I should be seeing. does anyone have a link to the wiring schematic
Bedrck47
Elizebethtown, PA
Wiring Diagrams for a 03 model the 04 model is the same
Check both fuses with a meter
  • 119-01.pdf
  • 119-02.pdf
  • 119-03.pdf
  • 119-04.pdf
D
danclow
alberta
yeah I did check both fuses and they were good, I saw on a video that on the 07 expedition it had to do with a bad ground but when I pulled apart the connectors I couldn't see any sign of damage
03EXPO4x4
Arkansas
I am having a problem with my passenger side only. Where are the fuses located?
Bedrck47
Elizebethtown, PA
03EXPO4x4
Fuse panel is behind passenger side kick panel Check fuse #18 and #118 But both fuses are for both sides look at the prints that are on this thread they are for the 03 model but the 04 is the same
k9education
I had a similar problem to the OP on my '11 and it turned out to be the relay. The relay also fried the wiring harness attached to it.
D
danclow
alberta
I have talked to more thatn one case of it being the climate controlled seat module, I think I will try that.
