Damn, I broke it........
Erich Zeppelin
Destruction Bay, Yukon Territory
Pulled my instrument cluster to fix the flickering odometer, but when I tried to remove the light switch there was no notch at the bottom, so I tried to pry it out and broke the face off. Inside was a slide lock, slid that and she popped right out. There are two connectors on the back of the switch and a third connector sitting in a red cup that is not connected to anything, what option was it for? Oh, and now my auto headlamps don't work........
B
bedrck46
If you like I can send you a copy of the wiring diagram when I get back home tomorrow
When you tried to remove the knob did you try to pull it out like you were turning on the fog lights? What are the color of the connectors or let me know how many wires are on the one that isn't connected
B
bedrck46
these should be the 3 connectors for the switch
B
bedrck46
wiring diagram for autolights
check the fuses
Erich Zeppelin
Erich Zeppelin
Thanks bedrck46, pulled the switch out again (broke it again) found out I had put the auto headlamp connector in the red cup instead of plugging it in to the back of the switch. Everything works great! Thanks again, the diagrams helped!
