Deep Snow Dash Warnings
Shotgun76
Suburban Chicago
Been up in the U.P. for a few days during blizzard conditions; got about 30" of snow since Monday. Driving a '24 Expedition Max SPP on 18" General Grabber A/T that came off a '25 Expy Tremor. Cabin is 9 miles or so from nearest paved road and at least a mile from nearest plowed county road. As such, used 4L for maybe 5 miles but otherwise been in 2H 'Normal' mode. Have done some Eco driving too, just this morning, when we went to town, travelling about 35 min on plowed asphalt roads. Went to drive tonight and warnings were coming up saying Advance Trac requires servicing, brakes need servicing, ABS light was on, and when I went to change drive mode to 'Slippery' it said drive modes were not available. Drove for about 45 min on unplowed roads this evening in 2H. I'm assuming a bunch of sensors are packed with snow and vehicle otherwise seems fine. Any thoughts? TIA!
Fastcar
Army
FL
Yup, that would be my guess as well.
Fastcar
Army
FL
You might want to check your air filter as well. Running through 30" of snow will pack it in everywhere.
Trainmaster
Old School Member
Rockaway Beach, NY
Sounds like an ABS issue from the snow and moisture... It will probably clear up. Otherwise, how old is your battery?
tominwi
Up North
Snow and ice and slush here last week and during our 2.5 hour drive home it seemed the lane-keeping feature was not working. Not a big deal for me cuz I tend to turn it off anyway but it had me thinking "where are the sensors/cameras and which are responsible for that" and of course the manual is no help, or at least I couldn't find anything. Anyone know where there's a rundown on them?
Presumably b/c I filled-up and washed the Expy upon return home the lane-keeping will work again next time I try it.
DieselMonk
Atlantic Canada
Got the same problem with my blind spot sensors. After a 500mi drive in cold temp, snowy and icey roads my sensor go on and off all the time now. Gonna stick my truck in the car wash tomorrow and hopefully that fixes that.
bb37
Member Relations Specialist
Indiana
I was driving in a heavy rain storm last summer when I was informed that lane keeping and adaptive cruise control were no longer available due to a sensor problem. I assumed that the heavy sheets of rain on parts of the windshield that were untouched by the wipers was the culprit. Rain stopped. Stuff worked again. Maybe I need to get on a ladder and put some Rain-X on the top center of the windshield.
LokiWolf
Moderator
Richmond VA
This thread is a mismatch of multiple issues and symptoms all related to Winter weather.
Most likely one of your ABS Sensors got caked with snow/ice. Spraying them down with a Silicone or PTFE based lubricant will help with this. Plus just checking to make sure the connectors are fully engaged. Without accurate wheel speeds certain modes will not engage as they require Traction Control to be fully active. You can ALWAYs Engage 4H/4L using the buttons.
Ding, Ding, Ding
Different issue. Camera is the issue. Most likely the main one at the top of the Windshield. "Snow and ice and slush", all things lane keep should not be used in, and ironically could have caused the issue in 2 different ways as to why it wasn't engaging. 1. The build up on the lane marking on the actual road preventing the system from seeing the lines properly. 2. Build up of slush/water in front of the camera at the top of the windshield. Most likely it was a combo of both.
Yep 100%! I do full treatment on my whole windshield on all of my vehicles, but prep is FAR more important than the product you chose. You need to Glass Clay, and polish before you apply anything. And historically I use RainX. It doesn't last as long, and needs to be reapplied more often as some of the more laong lasting Ceramic flavored options, but it is FAR easier to strip off, and start over. Pair it with the RainX windshield washer fluid, and you have a GREAT combo!
Fastcar
Army
FL
I haven't driven out of FL before April 15 in 20 years. So, no problems for me.
Fastcar
Army
FL
Thinking about it, we have the Expy in the car wash a minimum of every other day. No adverse reaction to the water from the under carriage spray.
tominwi
Up North
Thanks my lane-keeping stopped working AFTER I'd encountered snow/ice/slush. Highway was clean.
I'm just surprised the system doesn't alert me "your camera is occluded thus lane-keeping can't work".
I remain perplexed as to where Ford might explain where the various cams and sensors are and what each does... guess I'll look in the Service manual. Yep, there it is, the Image Processing Module A IPMA is located top-middle windshield and signals the Lane-Keeping System LKS among other things. Man, this vehicle is complex...
LokiWolf
Moderator
Richmond VA
Correct, water not in a solid or semi solid form is less likely to be an issue, as it flows and moves away from sensors and cameras...
Snow/Ice/slush typically causes more of an issue, both for sensors, and cameras.
