does anybody know where the reverse wire is located?
ENVIEDSOLDIER
hey guys title says it all i installed a HU but wasent really sure how to do the backup cam i finally figured it out i just need to know where/which wire i need to tap into
also the parking brake wire
thanks
Hamfisted
Ft Lauderdale
thanks
The reverse wire in the harness should be black with pink stripe. But always test it with a multimeter to verify. What HU are you installing? I know on Pioneers there is a wire to switch around in on the back of the HU to make it think the parking brake is always on. Do a web search for this for your brand of HU.
-Mike
E
ENVIEDSOLDIER
-Mike
Where is that harness located is it the same one my HU plugs up to?
nardone24
Orlando
Reverse is Green/brown in the driver's kick. If you have the reverse sensors, your job is even easier. Set the parking brake and put the truck into reverse. Follow the beeping noise to this module.Disconnect the harness from the module and the reverse is in that plug
