dome & sun visor lights not working
dpounders
All of my dome / reading lights don't work when the doors are shut. The dome / reading lights come on when you open the door. I looked at the wiring & it has three wires. I am assuming that one is a ground, the other is 12v supplied when the door opens (which I tested fine), and the other should be a constant 12v (which I tested bad). I checked all fuses and they are fine. I also changed the relay. My conclusion is that there is a burnt or disconnected wire somewhere but I'm not sure which way the wires run so I don't know where to start.
JUST4FUN
Admin
Moderator Administrator
Il
is the dimmer sw working?
D
dpounders
dome lights
Found the problem. The supply wire located in the side floor channel on the passenger side was burnt out along with several other wires. I spliced the wire back together and everything started working.
