Hey gang,
I'm working on my 2016 Exped Platinum. The other day my bride told me that when she got out to the truck, she noticed that the running board was extended. When she go in, the lights came on as expected, but when she closed the door, the running board did not retract and the puddle and interior lights did not go out like they normally do.
I did some testing.
- FORScan shows B1175:01 Drivers Door Ajar Switch
- Replaced with 3F2Z-13713-AA. Problem remained. I checked the old switch and it worked as expected (normally closed, open when pushed)
- Interior lights do eventually go out after about 10 minutes if the car is off, which I'm assuming is the Battery Saver kicking in
The Haynes wiring diagram shows the Light Blue/Red wire from the door switch feeding the Interior Lighting System. However, when I go to that page, I can't really find it as an input. I'm assuming it goes to the GEM which acts as the control coils for the Interior Lamp Relay and Running Board Lamp Relay (which I'm assuming also somehow triggers the running boards themselves)
Any thoughts on where to check next? There's no real info on the GEM (number/location, ect).
Any help would be appreciated!
Craig
I did some testing.
Craig
