Draw on battery?
ydopen
Puckett, Ms
2 years ago the parking light/dash light was putting a draw on the battery. I pulled the tail lights and the front markers out. Wiggled them and it has been fine for 2 years. Now im getting a draw on the battery from somewhere else
Sent from my SCH-R970X using Tapatalk
B
bedrck46
how much of a draw are you getting it would help to know that figure
stamp11127
Temple, Georgia
Do a YouTube search for "parasitic draw test" which describes how to find which circuit(s) has the draw.
ydopen
ydopen
Puckett, Ms
Thanks fellas. I can put a meter on it and it falls a number about every 5 seconds.
B
bedrck46
what do you mean by "falls a number about every 5 seconds"
what is the amp reading?
ydopen
ydopen
Puckett, Ms
Oh. Hmm. Im new to this. I mean after I jump it off and let it run 5-10 min. I can put the meter on it and its on say 12.70 then after 5-10 seconds it falls to 12.69
stamp11127
Temple, Georgia
Does your meter measure current? Or better yet, what make and model number is it?
Bedrck46 and I will walk you through electrical 101.
ydopen
ydopen
Puckett, Ms
I guess? Its over 14 when running but after cut off it starts dropping. I havent been driving it everyday. It mite be a slow enuff draw to be ok. But after sitting for a week it will zap a new battery
stamp11127
Temple, Georgia
First step is to check for battery problems. Disconnect one battery cable and take voltage readings over an hour on the battery posts. You shouldn't see any substantial drop in voltage.
B
bedrck46
You need to understand how to hook up your meter to get an amp draw reading. And also do what stamp11127 has recommended
stamp11127
Temple, Georgia
A normal draw is in milliamps (.001amp). There are 1000 milliamps in one amp so anything past a few milliamps would be of concern. The radio, memory seats and pcm have a slight draw and should be the only electronics that draw.
